10 years agoFloating point addition in vhdl
Hii I want to add 4 floating point no.what will be the result range.I am using library ieee_proposed; use ieee_proposed.fixed_pkg.all; this package.For example if I want to add two floating...
10 years ago --- Quote Start --- Excuse me for being a bit of a bore, but if you add up 4 values, an extension with 2 bits suffices ... --- Quote End --- Algorithmically yes - but not syntactically. Each addition in the fixed point library increases the bit size.
