11 years agoFlash Programmer, EPCS Reserved Fields are non-zero
Greetings - While trying to program a Spansion S25FL032P Flash device on my EP4CE10E22 Cyclone-IV board with the Nios II Flash Programmer, I get the following error messages: "Looking for ...
11 years ago --- Quote Start --- Greetings - While trying to program a Spansion S25FL032P Flash device on my EP4CE10E22 Cyclone-IV board with the Nios II Flash Programmer, I get the following error messages: "Looking for EPCS registers at address 0x00011100 Initial values: 9300023................. Not here: reserved fields are non-zero No EPCS registers found: tried looking at addresses .............. Error Code: 8" Do I need an override file and what should go in it? Any help would be greatly appreciated. Thank you very much, Falcon234 --- Quote End --- And btw, I also needed the override file copied to the \bin directory. I added the entry: [EPCS-010215]# EPCS32N(lead-free) sector_size = 65536 sector_count = 64
