16 years agoFlash memory size...
so i tested my flash memory using the HAL function (using word mode...) ret_code = alt_get_flash_info(fd, ®ions, &number_of_regions); the result was printed as: printf...
16 years agoThe second region starts right after the first one, so I would say that you can use all the flash as one big region and start at offset 0.
I don't know the specifics about the first "boot sector" region, it could just be a special erasing procedure. There could be more info in the flash datasheet.
