16 years agoFlash memory size...
so i tested my flash memory using the HAL function (using word mode...) ret_code = alt_get_flash_info(fd, ®ions, &number_of_regions); the result was printed as: printf...
16 years agoFound this:
Flash Region Structure: Number of Regions: 2 Offset: 65536 Region Size: 8323072 Number of Blocks: 127 Block Size: 65536 ok is there any way i could combine these 2 regions??? also when writing, should i offset my first data entry point by that (65536) much ?? (skipping the first region....) or i could write from offset 0...? my data length is 65035...
