16 years agoFlash memory size...
so i tested my flash memory using the HAL function (using word mode...) ret_code = alt_get_flash_info(fd, ®ions, &number_of_regions); the result was printed as: printf...
16 years agoThe code output only reports the size of the first region, which seems to be 64kbytes, split in 8 blocks of 8kbytes each.
Could you display the size of the second region? From the datasheet, it seems that this flash memory has a "boot sector" option, and I'm guessing that the first region reported is your boot sector.
