15 years ago
Flash memory problem
Hello, is it true that I cannot write 1MB of data into flash memory (4M)?
I am using Altera DE2 Board. My code is as follow:
--- Quote Start ---
# include <stdio.h># include <stdlib.h># include <unistd.h># include "altera_avalon_pio_regs.h"# include "system.h"# include "alt_types.h"# include "sys/alt_dma.h"# include "sys/alt_flash.h" # include "sys/alt_flash_dev.h"
# define loop 262144# define size 1048576
int main ()
alt_flash_fd* fd;
int ret_code, i;
int *src_ptr;
int *dest_ptr;
src_ptr = SDRAM_BASE + 0x200000; //Location of data written in SDRAM
dest_ptr = EXT_FLASH_BASE; //Location of data written in flash
//Open flash
fd = alt_flash_open_dev(EXT_FLASH_NAME);
if(fd!=NULL)
//Generate data into SDRAM
for(i=0;i<loop;i++)
IOWR(src_ptr, i, i);
//Write data into flash
ret_code = alt_write_flash(fd, 0, src_ptr, size);
if(ret_code != 0)
printf("Error writing into flash: %d\n", ret_code);
exit(1);
//Read from flash
for(i=0;i<loop;i++)
printf("Value at %X is %d, written at is %d\n", dest_ptr, *dest_ptr, IORD(src_ptr, i));
dest_ptr++;
}else
printf("Unable to open flash\n");
exit(1);
alt_flash_close_dev(fd);
return 0;
--- Quote End ---
I keep on getting error msg: Cannot write into flash and the error code is -5. pls help me. i am not sure whether is my coding problem or writing 1MB into flash is a special case. pls help! thanks!
    The -5 means EIO code (see errno.h file)
    This can be generated if HAL driver can't erase the flash block.
    Are you sure the flash is not write protected?
    Then, try initially to write a small amount of data, not the complete 1M buffer.
