MK_ABQ
Contributor
3 years agoFlash memory not detected - Arria 10 Development kit
hello, We have a new development kit ( Intel Arria 10 GX FPGA Dev board - DK-DEV 10AX115S-A). I can program the sof and do the initial fpga check with blinky LED. Now, I want to try programming the...
NurAiman_M_Intel
3 years agoHi,
I believe our team has response to your query through Intel Premier Support(IPS).
-the mode is passive parallel x32. The option start address and the .SOF start address should be set accordingly to the memory map, the .sof page should be 1.
-To program the .JIC file you have to use the JTAG mode. You can Auto detect the JTAG chain and than add the .JIC file to the Arria 10 device.
We will continue to provide our support through IPS for more information.
Aiman
