MK_ABQ
Contributor
3 years agoFlash memory not detected - Arria 10 Development kit
hello, We have a new development kit ( Intel Arria 10 GX FPGA Dev board - DK-DEV 10AX115S-A). I can program the sof and do the initial fpga check with blinky LED. Now, I want to try programming the...
NurAiman_M_Intel
3 years agoApologize for the incorrect link. Please refer below for the community case:
Aiman
MK_ABQ
Contributor
3 years agoHi Aiman
I do not understand the response in that link which was marked as a solution. The following sentence is not clear " found a way around this problem by bypassing the MAX FPGA 5M2210Z, i delete the Max FPGA 5M2210Z and then send the 10AX115S2F54 right up before the 10X115S2 FPGA. Make sure, there is a tick on Program/configure. Click Start to install"
