15 years ago
Fixed-point multiplication with "altmult_complex" megafunction
I am using the altmult_complex (complex multiplier) with inputs dataa (both real and imaginary) having 16 fractional bits, and inputs datab (both real and imaginary) having 2 decimal bits and 14 fractional bits. Dataa inputs are signed while datab inputs are unsigned.
I know that the output of the megafunction block would be singed results:
-> real = [(dataa_real * datab_real) - (dataa_imag * datab_imag)]
-> imag = [(dataa_real * datab_imag) + (dataa_imag * datab_real)]
Since the multiplication has both decimal and fractional bits, I'd like to know how many bits the outputs would have if I restrict the output to 16-bits in total.
Since 0.16 * 2.14 = 2.30 (32 bits), would restricting output to 16-bits give 2.14? [x.y -> x=decimal bits and y=fractional bits]
Also, would it be better if I use the fixed-point vhdl package?
Appreciate your help and guidance.
    The answer is yes to both of your questions, unless you multiply the two maximum negative numbers.
    Even more useful is the fixed point rules. If you have a 16 bit number with 8 bit integer and 8 bits fraction, you multiply it by a 10 bit number with 3 bits integer and 7 bits fractional, you get an 11.15 bit result. You simply add together the integer and fraactional bits.
    So the 11.15 would have the first two MSB bits as the sign bits?
    If so, can the second sign bit be discarded while implementing something like addressing a RAM?
    you should never discard any bits, unless you can garantee you are not multiplying two max negative numbers.
    And if you discard any bits like this, it should be the MSB, not the 2nd bit.
    My implementation requires me to multiply a 14-bit number with a 18-bit number, and take 10 MSB bits as my output. So I simply let all the 32-bits be outputted and then discarded the 22 LSBs.
    So after reading that link I posted earlier, I thought why should I keep two sign bits in my 10-bit output and thought of discarding the the second MSB.
    Leaving all the 10 MSB as my output should be fine I suppose?
