15 years agoFixed-point multiplication with "altmult_complex" megafunction
Hi, I am using the altmult_complex (complex multiplier) with inputs dataa (both real and imaginary) having 16 fractional bits, and inputs datab (both real and imaginary) having 2 decimal bits a...
15 years ago --- Quote Start --- Since 0.16 * 2.14 = 2.30 (32 bits), would restricting output to 16-bits give 2.14? [x.y -> x=decimal bits and y=fractional bits] --- Quote End --- altmult_complex knows nothing about fixed point, as you may have noticed. Restricting it's output it will give you the 16 less significant bits, which is not what you want. Instead, you can either a) use altmult_complex with a 32 bit output and then just select the 16 MSBs. b) use VHDL's complex package c) do it by hand in VHDL Any way is a good way.
