14 years agoFitter problem
Hi All, I have embarked on a project to develop a stopwatch which outputs seconds and minutes as a binary value. I am using two separate 8-bit LED boards connected to the MAX7000S ...
14 years agoYou simply need to conditionate the count increment to the button status.
For example, you can change the code you previously posted into: ... if(clk_out'event and clk_out='1' and button = “10”) then ...
