14 years agoFitter problem
Hi All, I have embarked on a project to develop a stopwatch which outputs seconds and minutes as a binary value. I am using two separate 8-bit LED boards connected to the MAX7000S ...
14 years agoThank you Lethenstrom.
Thank you very much for your advice. I did exactly what you said, however I was still getting routing problems. Therefore I reluctantly had remove the seconds display all together instead I have that pulsing on 1 led whilst the minutes count up to 120 on the same LED board. It works on the CPLD now. Thanks again :)
