14 years agoFitter problem
Hi All, I have embarked on a project to develop a stopwatch which outputs seconds and minutes as a binary value. I am using two separate 8-bit LED boards connected to the MAX7000S ...
14 years agoCris72 is correct the EPM7000S since it is macrocell based architecture it will be limited in routing resources. Furthermore, the macrocell architecture is not very scalable and therefore in the newer MAX II and MAX V it is FPGA based architecture with an internal flash for configuration.
/Boris
