FIR II core IP outputs incorrect data.
- 5 years ago
Would you mind to help opening a new thread on this. Thank you very much.
Regarding your latest inquiries, as I understand it from the Figure 13. Time-Division Multiplexing to Save Hardware Resources in user guide, yes, the IP is expecting you to feed serialized data from 2 channels when your clock rate is 2x of sample rate.
Chee Pin
- alperenpalp5 years ago
OK that's kind of clear for me right now.
What about the interpolation filters? I set the input sample rate to 100MSPS and clock rate to 100MHz. I get 74bits of output for every clock cycle. I assume each output value represents two samples, is that correct?
If it is true, could you tell me which part of the output is the first output? Lower part or the upper part?
Thanks!
