12 years agoFIR Compiler II multichannel operation
Hi all. I'm using FIR compiler II megafunction to create a block with the following parameters: Decimation filter this N = 2; Number of channels : 11; Clock frequency : 50 MHz; Input...
12 years agoI didn't describe the problem, my fault.
I have 11 fir filters connected in series, each with decimation factor = 2, clock frequence = 120 kHz,same coefficients and different input sample rates (because of the decimation): 1. 120 kHz 2. 60 kHz 3. 30 kHz 4. 15 kHz 5. 7500 Hz 6. 3750 Hz 7. 1875 Hz 8. 937,5 Hz 9. 468,75 Hz 10. 234,375 Hz 11. 117,1875 kHz It's working, but can't fit in our FPGA, even in case of increasing clock frequence. Thats why I want to do it with one filter and 11 channels. So, I want to use this channels with different frequences. I hope I explained the problem clear. What do you think about it?
