16 years agoFilter & decimation implementation on AD7401
Hello everybody! We have chosen the AD7401 Sigma Delta modulator for our project, translated the Verilog code given by the datasheet into VHDL and are now confused about the results of the simu...
14 years agoI use it but it doesn't work correctly.Because the DATA[15..0] I get was not stable and fluctuates about 1000,which it's terrible for the measure of a fixed voltage.I wrote a simple I2C (not the standard) to get the DATA[15..0] from the FPGA and send to DSP.
What did you do with the DATA[15..0]?Is it stable for a fixed sampling voltage?And how is the linearity of the AD7401 used of the filter code you wrote? I'm really sorry to bother you to answer this question, but I do encounter difficulties.
