15 years agoFIFO issues
Hello all, I've been working on a project involving the Altera FIFOs and things seem to be largely well. We've encountered one significant problem however and have had no luck debugging it. ...
15 years ago --- Quote Start --- wrclk and rdclk must be feeded by a real clock signal, and you must use the enable to control the read/write --- Quote End --- Thanks, I'm not sure I understand what you are saying. Are you saying that for some reason the buttons on the board can't be used as a clock for the FIFO? We've had no problem before and we did encounter the same problem using a "real" wrclk though we've been using rdclk from a button the whole time. It seems to work fine other than dequeueing the last element. As far as "enable to control the read/write" are you referring to the rdreq and wrreq lines or something else that we've managed to miss? Again I _think_ we are handling the rdreq and wrreq correctly (we have them be a "1" only on the clock edge we wish to read or write). Sorry for all the questions, I'm just not sure what you're suggesting.
