15 years agoFIFO issues
Hello all, I've been working on a project involving the Altera FIFOs and things seem to be largely well. We've encountered one significant problem however and have had no luck debugging it. ...
15 years agoThanks for the offer. Sorry if I'm including too much code here, but I thought I'd hand off the whole thing. The same thing happens if we use a DE2 board.
In order to make it easy to see what's happening we've wired it up to the switches and LEDs of the DE2 board using the standard QSF names. And sorry indenting is getting trashed in the cut-and-paste to here. The relevant code for what buttons are going where follows: --- Quote Start --- assign data_in = {14'd0,SW[4:3]}; assign HEX00 = data_out[7:0]; .data(data_in), .rdclk(KEY[0]), .rdreq(KEY[2]), .wrclk(KEY[3]), .wrreq(KEY[1]), --- Quote End --- Mark --- Quote Start --- `define n0 8'b11000000 `define n1 8'b11111001 `define n2 8'b10100100 `define n3 8'b10110000 `define n4 8'b10011001 `define n5 8'b10010010 `define n6 8'b10000010 `define n7 8'b11111000 `define n8 8'b10000000 `define n9 8'b10010000 `define na 8'b10001000 `define nb 8'b10000011 `define nc 8'b11000110 `define nd 8'b10100001 `define ne 8'b10000110 `define nf 8'b10001110 module bin_2_hex(bin, hex); input [3:0] bin; output [7:0] hex; assign hex = (bin == 4'h0) ? `n0: (bin == 4'h1) ? `n1: (bin == 4'h2) ? `n2: (bin == 4'h3) ? `n3: (bin == 4'h4) ? `n4: (bin == 4'h5) ? `n5: (bin == 4'h6) ? `n6: (bin == 4'h7) ? `n7: (bin == 4'h8) ? `n8: (bin == 4'h9) ? `n9: (bin == 4'ha) ? `na: (bin == 4'hb) ? `nb: (bin == 4'hc) ? `nc: (bin == 4'hd) ? `nd: (bin == 4'he) ? `ne: `nf; endmodule module FIFOtest( CLOCK_50, SW, LEDG, HEX0, HEX1, HEX2, KEY ); //master input CLOCK_50; input [17:0] SW; output [8:0] LEDG; output [7:0] HEX0,HEX1,HEX2; input [3:0] KEY; wire [15:0] data_in; wire [15:0] data_out; wire [3:0] size; wire rd_wr; wire [7:0] HEX00,HEX11,HEX22; //wire enable; assign data_in = {14'd0,SW[4:3]}; assign HEX00 = data_out[7:0]; bin_2_hex inst0(HEX00, HEX0); bin_2_hex inst1(HEX11, HEX1); bin_2_hex inst2(HEX22, HEX2); FIFO16by16 write( .data(data_in), .rdclk(KEY[0]), .rdreq(KEY[2]), .wrclk(KEY[3]), .wrreq(KEY[1]), .q(data_out), .rdempty(LEDG[1]), .rdusedw(HEX11), .wrfull(LEDG[0]), .wrusedw(HEX22) ); endmodule // synopsys translate_off `timescale 1 ps / 1 ps // synopsys translate_on module FIFO16by16 ( data, rdclk, rdreq, wrclk, wrreq, q, rdempty, rdusedw, wrfull, wrusedw); input [15:0] data; input rdclk; input rdreq; input wrclk; input wrreq; output [15:0] q; output rdempty; output [3:0] rdusedw; output wrfull; output [3:0] wrusedw; wire sub_wire0; wire [15:0] sub_wire1; wire sub_wire2; wire [3:0] sub_wire3; wire [3:0] sub_wire4; wire wrfull = sub_wire0; wire [15:0] q = sub_wire1[15:0]; wire rdempty = sub_wire2; wire [3:0] wrusedw = sub_wire3[3:0]; wire [3:0] rdusedw = sub_wire4[3:0]; dcfifo dcfifo_component ( .rdclk (rdclk), .wrclk (wrclk), .wrreq (wrreq), .data (data), .rdreq (rdreq), .wrfull (sub_wire0), .q (sub_wire1), .rdempty (sub_wire2), .wrusedw (sub_wire3), .rdusedw (sub_wire4), .aclr (), .rdfull (), .wrempty ()); defparam dcfifo_component.intended_device_family = "Cyclone II", dcfifo_component.lpm_hint = "MAXIMIZE_SPEED=5,", dcfifo_component.lpm_numwords = 16, dcfifo_component.lpm_showahead = "OFF", dcfifo_component.lpm_type = "dcfifo", dcfifo_component.lpm_width = 16, dcfifo_component.lpm_widthu = 4, dcfifo_component.overflow_checking = "ON", dcfifo_component.rdsync_delaypipe = 5, dcfifo_component.underflow_checking = "ON", dcfifo_component.use_eab = "ON", dcfifo_component.wrsync_delaypipe = 5; endmodule --- Quote End ---
