22 years agoFIFO Interface
The fifo interface (http://www.ece.utexas.edu/~desimone/fifo_interface/) component interfaces a FIFO megafunction to the Avalon bus so the master can read or write it like a peripheral. It's pre...
22 years agoHello Mike,
Thanks for your very useful contribution. I do however have a question which seems not to be answered by your documentation: I have created a read fifo (data towards nios) using your tool. On the processor port symbol appears a "clk_en_from_the_readFifo", in addition to the "fifo_rdreq_from_the_readFifo". I expect that the fifo_rdreq should go to the rdreq input in the fifo (external to nios) which I have generated using the megawizard, but whats the use of clk_en? On the symbol which I have got from the wizard I have no clk_en input. I browsed your documentation but could not find any mention of this pin. Can you give me a hint? thanks Hennnig Risoe national laboratory Denmark
