14 years agoFIFO (Dual port ram)
Hello, I am trying to perform 3x3 kernel image convolution by using 2 FIFO and 3 shift registers so that I can implement a pipelined fifo I will prefer not to use the FIFO ip...
14 years agoHello,
I am using the scfifo but I keep getting an error that makes no sense. I am sending values (data) into the fifo and my w_enable<= 1. But my usedw is always 1? and full is always 0. My word length is 8 and the number of Bits =20. My code might be a little bit confusing because I have the other variables that I wil use later once I understand how 1 fifo works. I am trying to use 2 fifo and 3-shift register to for convolution pipeling. But the important part is the enable block
module conv_buffer3x3(CLK,reset,en,inPixel,fBuff,line_end,P1,P2,P3,P4,P5,P6,P7,P8,P9);
parameter nRows=8;
parameter nCols=8;
parameter kRows=3;
parameter kCols=3;
parameter INT_WIDTH=20;
parameter ADD_WIDTH= 5; //line is (k-1)*N +K;
parameter KxK=9;
parameter filled= 63; //line is (k-1)*N +K;
input CLK, reset,en,line_end;
input inPixel;
output reg fBuff;
output reg P1,P2,P3,P4,P5,P6,P7,P8,P9;
reg fiforeg1_1,fiforeg1_2,fiforeg1_3;
reg shiftreg1_1,shiftreg1_2,shiftreg1_3;
reg shiftreg2_1,shiftreg2_2,shiftreg2_3;
reg shiftreg3_1,shiftreg3_2,shiftreg3_3;
wire full_f1,full_f2;
wire usedw_f1,usedw_f2;
wire output_f1,output_f2;
reg re_f1,re_f2,we_f1,we_f2;
wire empty_f1,emptyF2;
reg data_f1, data_f2;
reg cnt;
always @(posedge CLK) begin //or negedge RST)
if (en) begin
cnt<=cnt+1;
if (cnt>=0 && cnt<filled) begin
fiforeg1_3<=inPixel;
fiforeg1_2<=fiforeg1_3;
fiforeg1_1<=fiforeg1_2;
if (cnt>2) begin
data_f1 <=fiforeg1_1;
we_f1 <=1;
fBuff<=0;
end
end
end
else begin
//shiftreg1_1<=0; shiftreg1_2<=0;shiftreg1_3<=0;
// fiforeg1_1<=0; fiforeg1_2<=0; fiforeg1_3<=0;
cnt<=0;
we_f1<=0;
end
end
fifo_v1 FIFO1(CLK,data_f1,re_f1,we_f1,empty_f1,full_f1,output_f1,usedw_f1);
//fifo_v1 FIFO2(CLK,data_f2,re_f2,we_f2,empty,full_f2,output_f2,usedw_f2);
endmodule
Thank you
