18 years agoFFT timing?
Hi I need to perform a 256 point FFT operation. I use the SOP and EOP signals to indicate the start and end of operation with sink_ready always high. My simulation suggests that the input data is per...
18 years agoIs it possible that by adding output pins to a specific design can change the timing of the system and hence the system will produce incorrect output. I seem to have this problem if I remove or add output pins on the bus feeding data to the FFT Megacore function the timing simulation yields different results. Why would this happen?
