16 years ago
Fast IO register constraints won't apply
I have a SRAM memory interface in my design and I registered all the signals in a component called mem_ctrl. I set these registers as fast input/output registers in assignment editor. But I got a bounch of warnings like the following:
Warning: Can't pack node "mem_ctrl:COMP_MEM_CTRL|addr[0][0]" and I/O cell a_tap[0]. The node and I/O cell are connected across a Design Partition boundary.
And it takes almost 6.5ns for a signal going from its register to the pin according to the timing analyzer.
Should I put all those registers in the top level to apply fast IO register constraints? Or is there anything else I should pay attention to? (the mem_ctrl component is in the top partition, and I don't understand why the message said the signal needs to across partition boundary).
Your help is very much appreciated.
Hua
    It was actually because the signal was used in signal TAP. Removing them from the signal tap (moving those registers to the top level essentially did that) will fix the problem.
