15 years agoFast frequency generation/ modulation
Hi there
I am not really familiar with FPGA families and their spped grades etc Is anyone here able to telll me what is the fastest clock signal and PWM signal I could output from a Altera FPGA or CPLD?? I am working on a project that I need to e generate a signal with a frequency that can vary from 0.1MHz to 50MHz and vary the duty cycle from 10% to 90%. Is there a device you could reccomend? thanks11 Replies
An I/O rate of 0.1MHz to 50MHz is pretty slow for FPGAs. Any device will do.
I would recommend looking at the low-end devices. If you do not need much logic, then the MAX II devices are good (there are now MAX V devices too). There are also the low-end Cyclone series devices (Cyclone III, IV, or V). Cheers, Dave
