16 years agoFalse high inputs
Using a Cyclone II 2C20F484C7 fpga, and having some trouble with false high inputs. Basically if I have a switch connected, in other words an open line, it seems to default to reading it as a h...
16 years agoThanks for the explanation. I think the problem isn't particularly related to FPGA (except for the weak pull-up option). You can't use a single throw switch without an additional resistor to drive digital logic.
