16 years agoFalse high inputs
Using a Cyclone II 2C20F484C7 fpga, and having some trouble with false high inputs. Basically if I have a switch connected, in other words an open line, it seems to default to reading it as a h...
16 years agohe means if you have a switch that is normally open, and when it is closed it connects to VCC, you will need to disable the internal pullup resistor and use an external pulldown resistor (so that the pin reads 0 when the switch is open). alternatively you can connect the switch to GND, and enable the pullup resistor which will require no external components. adjust accordingly in your HDL.
