Fail to enumerate RTile PCIe in the AVSTx8 configuration
Hi Rong,
May I know whether the use of a design partition could cause PCIe detection to fail when using the AVST x8 configuration?
The OFS design is able to detect the PCIe device and perform testing successfully in the AVST configuration on the same hardware. Therefore, I would like to understand whether there are any specific limitations or considerations related to design partitioning that could affect PCIe enumeration in the AVST x8 configuration.
Divya
>>The same hardware means the same dev kit or the same FPGA device? The Agilex7 I-series dev kit supports AVST x8 for sure. If you're using the same FPGA device on a different board, you need to check the board schematic to make sure.
If the design partition you mentioned is CvP, I wonder how you create an image for the flash.
Rong
