16 years agoFail to Boot Software from EPCS16
Hi, I have made a simple custom system with a EP3C16Q240, EPCS16,SDRAM,an AS connector,a JTAG connector and a 50Mhz system clock in which MSEL[0:2]=[010],VCCIO=3.3V.The SOPC contains a cpu with re...
16 years ago --- Quote Start --- Have you prove with 'no code at reset' in nios bsp settings? --- Quote End --- Thanks for the advice. It worked.
