16 years agoFail to Boot Software from EPCS16
Hi, I have made a simple custom system with a EP3C16Q240, EPCS16,SDRAM,an AS connector,a JTAG connector and a 50Mhz system clock in which MSEL[0:2]=[010],VCCIO=3.3V.The SOPC contains a cpu with re...
16 years agoI've got it!
The problem was not the fpga extra hardware (MSEL and all was ok) nor the epcs_controller in nios. The problem was the top-level pin assignements in cyclone III. I was using DATA0, DCLK, nCSO and ASCO signals but they weren't well asigned to fpga's configuration pines. Now I can access ecps via nios and i can use flash-programmer. Thank you very much for your help.
