10 years agoFacing problems in constraining Negative Setup Slack
Hello all, I am facing problems in constraining Negative Slacks (for a 50Mhz clock and 150MhZ clock both generated clocks). I had a negative slack of -59 which was because of using a 44_24 LPM ...
10 years agoIt is need entire project because timing depend on a lot of things (device, pinout, etc..) but I don't think I have enough time to do your project analysis now. Use Timequest to find what path are failing and then edit design..
You use C8 device.. maybe you can upgrade to a faster speed grade? Another way is to change phase shift to improve setup times..
