10 years agoFacing problems in constraining Negative Setup Slack
Hello all, I am facing problems in constraining Negative Slacks (for a 50Mhz clock and 150MhZ clock both generated clocks). I had a negative slack of -59 which was because of using a 44_24 LPM ...
10 years agoIf you have a timing problem you can solve it editing design files or if violation is small (ex. 0.5 ns) changing optimization parameters or trying design space exploration (multiple compile seed).
