Vasileios_Anastasiou
1 year agoF-Tile debug toolkit not loading properly
Hi. I'm using an SDI example design with serial loopback generated with Quartus Prime Pro 24.3 for Agilex7 (AGFB027R24C2E2V device) FPGA. I'm trying to load the F-tile transceiver toolkit for the RX...
Wincent_Altera
1 year agoHi,
Based on provided information, the issue was failing at the basic step and the system-console is not able to create tmp directory in the User directory.
Could you try to test with the different User or create a directory manually in the folder where see the error?
Wincent_Altera
