11 years agoEye diagram failure
Hi, I am using Altera V GT device for 10.3125 Gbps XFI link,with 322MHZ reference clock.The measured eye at my RX seems very bad and its not same as simulated results.We tried changing pre emph...
11 years agoHi Bala,
Generally the eye diagram at the RX would have significant dependency on the board setup as well. You could do a comparison between the TX output eye vs RX output eye. If the TX eye is clean, then you would need to further look into the board setup to see if there is any improvement area. By the way, you may try with RX equalization to see if it helps.
