14 years ago
Extracting .jic from cyclone III
Does anybody know if it is possible at all to extract and copy/open/read/write a design from a .jic file already installed on a Cyclone III FPGA?
If yes, what are the ways to prevent or control it?
Can somebody suggest any literature on this topic?
Thanks in advance
    --- Quote Start ---
    Before that You had to program DS28E01 with secret code with the use of the same FPGA.
    Can that be done several times?
    --- Quote End ---
    Yes. The code is rewritable
    --- Quote Start ---
    How to check, that DS28E01 really got programmed?
    --- Quote End ---
    You may use the "enabler" code and expose the enable signal in order to test its level after security check.
    --- Quote Start ---
    What is the form of the "Enable" signal?
    A constant high level even after the SHA-1 IFF module will be turned off or a pulse?
    --- Quote End ---
    If the security check is successfull, it goes high and keeps the level forever
