14 years agoExtract program from a MAX3128 with Quartus II and a USB Blaster
Hi, My company has assigned to me and old project of developing a board of I/Os. I have some prototypes to work with, but all the info and the programming of the pics is lost. I am tryi...
14 years agoHi,
yes - examine "Uploads" the configuration data only. Now you could either connect the Blaster to the new board and program (just do a copy) or you can (as ghogerheiden wrote) right-click and safe the file for other boards... The checksum depends on the file (being calculated by Quartus), the user code can be set by the user (either with autoincrement on every compilation) or manually and has no effect on program. If there is no Input, it's by Default all "F".
