17 years agoExternal Memory required for JTAG programming?
I am in the early stages of designing an RF transmitter that will operate with a Cyclone II. Testing is being done on a Cyclone II Starter Development Kit (EP2C20F484), but the final hardware will us...
17 years ago --- Quote Start --- Yes, correct. You may want to provide an optional AS configuration memory, if you have sufficient free pins available (at least as dual-purpose). It can be programmed through JTAG indirectly without needing an extra programming connector. --- Quote End --- By "indirectly" you mean the "flash-loader" design of Altera that can be programmed into the Cyclone?
