12 years agoExternal Interface-like connection HPS to FPGA
Hello all, I am trying to find a way to connect the HPS to the FPGA logic using an interface similar to those external interfaces which can be found in microcontrollers. Something with an addre...
12 years agoIn my design I have connected the "h2f_lw_axi_master" on the HPS to an "Avalon-MM bridge" component in QSYS. I then exported the slave side of the bridge to make the Avalon MM bridge available in my FPGA design.
The Avalon-MM interface is very easy to use the signals that are exported to the slave side are: (outputs) Write, Read, Address, WriteData (inputs) ReadData, ReadDataValid, WaitRequest. There are also ByteEnable and BurstCount signals that you may want to use for your application. Basically, on a write transaction the master sets "WriteData" and "Address" when "Write" is high, your slave then does whatever you need with that data. On a read transaction the master sets "Read" and "Address" the slave is expected to provide "ReadData" for the corresponding read address and set "ReadDataValid". If the slave cannot process a transaction it sets "WaitRequest". I think you can cause the bus to "hang" if you fail to respond to a readrequest but your FPGA code shouldn't allow it to do that. Full details here http://www.altera.com/literature/manual/mnl_avalon_spec.pdf
