roy970509
2 years agoExecution Issues with Intel Stratix 10 TX Board Test System (BTS)
Hello, I am encountering an issue with my Intel Stratix 10 TX series board, specifically model 1ST280EY2F551VG, while attempting to run the Board Test System (BTS). Below are the details: I am curr...
- 2 years ago
Hello
Good day,
You may try with the version that i suggested to check first.
Elina
Elina_Intel
2 years agoHi,
Do you have any update regarding your issue ? May i proceed with closing the case ?
Elina
- roy9705092 years ago
Thank you for your response. I apologize for the delay in checking your message. I have now tried running the program with the Quartus Prime Pro version 18.1.2.277, and encountered the following issue. I have already attempted all the methods mentioned in below message. Is this an issue that can still occur in this version, and can it be resolved by switching to the version you suggested? If not, I would appreciate any further advice you may have.
Failed to register GUI application!Please make sure the following settings are correct:-Make sure device list on JTAG chain is correct.-Only one application instance is opened.-All service is closed which is opened or claimed by system-console.-Connect the board through on board USB-Blaster II.If all settings are correct and still have the problem, you can try the following methods and then restart this application:-Lower Jtag Clock with "jtagconfig --setparam <cable> JtagClock <value>" command.-End java and jtagserver.exe process on Windows Task Manager.-Power cycle the board.-Restart your computer.-Reconfigure the system MAX image.
