13 years ago
execute different quartus version in command prompt
I have install quartus version 12.1sp1 in windows. When I taip quartus_sh <> in command prompt, it will execute v12.1 32-bits. Can i run it in 64-bits without go to the bin64 directory?
    --- Quote Start ---
    I am not using NIOS II IDE shell. quartus_sh --64bit command is not work also.
    --- Quote End ---
    That comment is not consistent with your original question - you asked about using the command-line. The NIOS II IDE shell *is* the command-line - its the Cygwin terminal.
    If you only ever want to use the 64-bit applications, add the bin64 directory to your path. You can probably create or edit a .bashrc file for the Altera Cygwin terminal to use, and inside that set your path.
    The --64bit option won't work until you try it on the 64-bit version of the application, i.e., the version in the bin64 folder.
    Cheers,
    Dave
    thank for reply, then got anyway can change the default path to 64bits in command prompt? because I am not using NIOS II IDE shell. quartus_sh --64bit command is not work also.
    --- Quote Start ---
    does "quartus_sh --64bit" load the 64 bit version?
    --- Quote End ---
    Nope, you get an error indicating that the --64bit option is not available with the current executable (a message about being 32-bit would be a little more informative!).
    Cheers,
    Dave
    Not as far as I can tell.
    If I want the 64-bit version to run I use a NIOS II IDE shell and type
    $ export PATH=`cygpath -u $QUARTUS_ROOTDIR/bin64`:$PATH
    $ quartus
    which puts the 64-bit executable in the path first (the cygpath call is needed to get the path format correct).
    Cheers,
    Dave
