13 years agoexecute different quartus version in command prompt
Hi, I have install quartus version 12.1sp1 in windows. When I taip quartus_sh <> in command prompt, it will execute v12.1 32-bits. Can i run it in 64-bits without go to the bin64 directory?
13 years agoNot as far as I can tell.
If I want the 64-bit version to run I use a NIOS II IDE shell and type
$ export PATH=`cygpath -u $QUARTUS_ROOTDIR/bin64`:$PATH
$ quartus
which puts the 64-bit executable in the path first (the cygpath call is needed to get the path format correct). Cheers, Dave
