14 years agoExample project for Arria II GX dev kit
Hello all. Does any have an example project for Arria II GX dev board (EP2AGX125 version) that includes all peripherials installed on the board? Thanks.
14 years agoI'm successfully implement a DDR2 and DDR3 memories and some pripherials in one project.
So, at now i try to add TSE_MAC in project. And i have problems. The tse modules connections is typically as other many projects. FPGA project compiles succesfully. Nios project also successfully compiles. But when i load project on board, then NIOS console show it:
Inst & Data Cache Initialized.
Setting up stack and global pointers.
Clearing BSS
Calling alt_main.
Entering alt_main, calling alt_irq_init.
Done alt_irq_init, calling alt_os_init.
Done OS Init, calling alt_sem_create.
Calling alt_sys_init.
and stops the loading. I research that app (ucos) stop at alt_sys_init.c:
void alt_sys_init( void )
ALTERA_AVALON_TIMER_INIT ( HIGH_RES_TIMER, high_res_timer);
ALTERA_AVALON_TIMER_INIT ( SYS_CLK_TIMER, sys_clk_timer);
ALTERA_AVALON_JTAG_UART_INIT ( JTAG_UART, jtag_uart);
ALTERA_AVALON_LCD_16207_INIT ( LCD, lcd);
ALTERA_AVALON_PERFORMANCE_COUNTER_INIT ( PERFORMANCE_COUNTER, performance_counter);
ALTERA_AVALON_SGDMA_INIT ( SGDMA_RX, sgdma_rx);
ALTERA_AVALON_SGDMA_INIT ( SGDMA_TX, sgdma_tx);
ALTERA_AVALON_SYSID_QSYS_INIT ( SYSID, sysid);
TRIPLE_SPEED_ETHERNET_INIT ( TSE_MAC, tse_mac);
at line altera_avalon_timer_init ( sys_clk_timer, sys_clk_timer); So, the sys_clk_timer period sets to 10 ms. It more than needed for most projects. But it can't init the timer....... Reset and Exception vectors are set to Oh-Cnip memory. Why? SOPC system attached: http://www.alteraforum.com/forum/attachment.php?attachmentid=5811&stc=1&d=1335511668
