EthernetBlasterII: Firewall - which network communication protocols/ports are being used
- 4 years ago
I am Farabi who will be supporting your request. I will answer your questions below:
- Are there any other ports that may come into play once a session is started?
- E.g. dynamically opened ports based on the type of use?
<ANS> No. Ethernet Blaster will only open HTTP port 80, SSH port 22 and Jtag-server port 1309
- Are any UDP-ports being used or is everything done via TCP?<ANS> every transmission will be using TCP only.
- Do the EthernetBlasterII initiate any TCP/UDP connections other than DHCP, or are all communication based on being initiated from the client?<ANS> All connection will be initiated from client.
You can first disable the firewall , to see if ethernet blaster ii can be detected in your network or not.
regards,
Farabi
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
