ochiang
2 years agoEthernet suggestion
Hi, I am using a Cyclone V SoC FPGA and I would like to inquire about the feasibility of using this component for Ethernet communication at speeds of at least 2.5Gbps. I am open to using either ...
Jeet14
2 years agoHi,
Yes, you need to write RTL logic for MAC+PCS & MDIO logic as well for external PHY's then you can directly connect it with XCVR Native PHY 2.5G.
Tiwari
- ochiang2 years ago
Hi Tiwari,
I am very grateful for your information; it has been very helpful to me.
However, I have some additional questions. There is already a Standard PCS within the Native PHY. When I select GigE 2.5G, it sets up to enable PCS 8b/10b. How is this different from the PCS you mentioned? Specifically, what additional PCS functionality do I need to implement? Could you provide some hints?
Are you referring to handling things like Ordered-sets?Thank you very much.
