ochiang
2 years agoEthernet suggestion
Hi, I am using a Cyclone V SoC FPGA and I would like to inquire about the feasibility of using this component for Ethernet communication at speeds of at least 2.5Gbps. I am open to using either ...
Jeet14
2 years agoHi,
Unfortunately, we don't have support for 2.5G ethernet support from the HPS or FPGA side on Cyclone V SX device.
On Cyclone V SX SoC FPGA, at HPS side you can use ethernet only 10/100/1000 Mbps.
But in Cyclone 10 GX device, you can use the 2.5G ethernet.
Tiwari
- ochiang2 years ago
Hi Jeet14,
thank you for your reply,I saw in the documentation that both the Cyclone V Transceiver Native PHY IP Core and the Custom PHY IP Core support GIGE-2.5Gbps PCS. Can't these be used to implement 2.5Gbps Ethernet?
