18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years agoOh just take it. You have to unzip this to c:\altera\72\nios2eds\components .Remember, in order for this to work, you'll have to hand edit the system.stf file for your project. Here is an example:
<sw_component id="INICHE_SL" name="NicheStack TCP/IP Stack" sopc_component_dir="altera_iniche_sl">
<sys_defines>
<define name="include_tcp" quote="no" value="1"/>
<define name="ip_fragments" quote="no" value="1"/>
<define name="dhcp_client" quote="no" value="1"/>
<define name="INICHE_TIMERS" quote="no" value="1"/>
<define name="MEM_WRAPPERS" quote="no" value="1"/>
<define name="TCP_ZEROCOPY" quote="no" value="1"/>
<define name="ALT_INICHE_SUPERLOOP" quote="no" value="1"/>
<define name="TELNET_SVR" quote="no" value="1"/>
<define name="IN_MENUS" quote="no" value="1"/>
<define name="ALT_NUMBIGBUFS" quote="no" value="100"/>
<define name="PING_APP" quote="no" value="1"/>
<define name="INCLUDE_NVPARMS" quote="no" value="1"/>
<define name="NET_STATS" quote="no" value="1"/>
<define name="DNS_CLIENT" quote="no" value="1"/>
<define name="IP_ROUTING" quote="no" value="1"/>
<define name="USE_PROFILER" quote="no" value="1"/>
<define name="FTP_SERVER" quote="no" value="1"/>
<define name="TFTP_SERVER" quote="no" value="1"/>
<define name="FTP_CLIENT" quote="no" value="1"/>
<define name="TFTP_CLIENT" quote="no" value="1"/>
<define name="SERVER_PUSH" quote="no" value="1"/>
<define name="VFS_FILES" quote="no" value="1"/>
<define name="WEBPORT" quote="no" value="1"/>
<define name="HTML_COMPRESSION" quote="no" value="1"/>
<define name="FOREIGN_LANG_SUPPORT" quote="no" value="1"/>
</sys_defines>
</sw_component> Jake
