18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years agoOkay... it seems you've downloaded the patch from the wiki correct? He's included a document that indicates which files he's modified. So what we actually did was run the patch on a 7.1 installation. Then we compared the modified files between the patched 7.1 version and the 7.2 version to see what changes we needed to make to get the superloop mode working. They were minimal and if I remembered off hand what they were I'd just give them to you. Bare in mind that there was other code that changed between 7.1 and 7.2 so you only want the necessary superloop changes.
However, didn't you look at this thread in the NIOS forum? http://forum.niosforum.com/forum/index.php?showtopic=8747 He's got a 7.2 version ready for download. I haven't used it but you could give it a shot. Jake
