18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years agoOK so i tried doing some simple socket programming....however am I right in assuming that I will have to use the MicroC/OS-II structure...
I have tried the following code, but Nios II IDE can't find the ipport.h and tcpport.h files, which contain all the socket programming fucntions... # include "sys/socket.h" # include <unistd.h> # include <string.h> # include <alt_types.h> # include <ctype.h> # include <errno.h> # include <stdio.h> # include <sys/alt_flash.h> # include "includes.h" # include "io.h" # include "ipport.h" # include "tcpport.h" # include "network_utilities.h" # define LOCAL_SERVER_PORT 1500 # define SERVER_PORT 1500 # define MAX_MSG 100 int main (int argc, char *argv[]) { int sd, rc, i; struct sockaddr_in localAddr, servAddr; struct hostent *h; if(argc < 3) { printf("usage: %s <server> <data1> <data2> ... <dataN>\n",argv[0]); exit(1); } h = gethostbyname(argv[1]); if(h==NULL) { printf("%s: unknown host '%s'\n",argv[0],argv[1]); exit(1); } servAddr.sin_family = h->h_addrtype; memcpy((char *) &servAddr.sin_addr.s_addr, h->h_addr_list[0], h->h_length); servAddr.sin_port = htons(SERVER_PORT); /* create socket */ sd = socket(AF_INET, SOCK_STREAM, 0); if(sd<0) { perror("cannot open socket "); exit(1); } /* bind any port number */ localAddr.sin_family = AF_INET; localAddr.sin_addr.s_addr = htonl(INADDR_ANY); localAddr.sin_port = htons(0); rc = bind(sd, (struct sockaddr *) &localAddr, sizeof(localAddr)); if(rc<0) { printf("%s: cannot bind port TCP %u\n",argv[0],SERVER_PORT); perror("error "); exit(1); } /* connect to server */ rc = connect(sd, (struct sockaddr *) &servAddr, sizeof(servAddr)); if(rc<0) { perror("cannot connect "); exit(1); } for(i=2;i<argc;i++) { rc = send(sd, argv, strlen(argv) + 1, 0); if(rc<0) { perror("cannot send data "); close(sd); exit(1); } printf("%s: data%u sent (%s)\n",argv[0],i-1,argv[i]); } return 0; }
