18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years agoAny BSD socket example can be used. The one indicated by Vizziee is a good start.
Just be careful with the header files to include. You should stick to the ones in the sockets server example, as they are not exactly the same than what you can see in some BSD sockets sample codes.
