18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years agoI'm not sure this is the way to go... If you use Ethernet as a raw transport medium you would need to write your own PC driver to replace the TCP/IP stack with your own and recover the raw Ethernet data. Sounds really difficult.
It's really simpler to use TCP/IP on your NIOS system, and the socket API is not that difficult to use. Have a deeper look at the simple socket server example. Once you open a TCP socket it's almost as easy to use as a character I/O.
