18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years ago --- Quote Start --- 2 - If you don't need the TCP/IP protocol layers and you just wanted to use ethernet as a raw transport medium. Then you could get away from the TCP/IP stack altogether and simply write/read raw data to/from the ethernet interface. However, you would have to completely control both ends of the connection and all connection points between. Jake --- Quote End --- Any hints/tips/sample code to point me in the right direction for using the ethernet as a raw transport medium...I can't seem to get my head around the whole TCP/IP protocol. cheers, Kushan.
