18 years agoEthernet Interface
Hi, I have a system (a probe) that is currently sending/receiving data from the PC terminal using a UART(RS232) connection. This was easy to configure/program, and the hardware was also easy to...
18 years ago --- Quote Start --- Hi, I wish to transmit/receive 16-bits of data in one go, I have already done the Web Server and Simple Socket tutorials, but they are way to complex for my needs....is there no equivalent for printf() / getchar() when uning the Ethernet... Kushan. --- Quote End --- You can use Altera Host-Based File System in which you can write the entire received data in a file and can examine it later. The receive() call in socket programming gives out the data packets.
